gloworm 30ci f9 fault code
09' and 'F' and 'flashing red LED' Water pressure sensor fault
F9 on some of the earlier boilers is a generic fault code not neccessarily a water sensor fault.Glow-worm have a plug in diagnostic fault finder which will reveal what the F9 relates to.
thats correct its called a diacom. or you could fit a new pcb which will give you a more specific code. Best call glow worm for repair-£215.
01773 828100
thanks for the replys it has only come on once so far after reseting the boiler it went away
