I have a gloworm 40ff boiler, danfoss fp715 HW/CH timer, and a Honeywell cm907 programmable thermostat.
This morning the temperature was set at 21, on the Honeywell unit, however the temperature managed to get to 25 degrees - the boiler was running constantly.
The normal setting on the danfoss timer is HW to Auto (a programme turns on in the am and pm for an hour) and the CH is always on - as the Honeywell cm907 controls via its own programme.
I turned the CH to off (on the danfoss) and the boiler continued, I also turned the HW to off and the boiler continued too. The only way to stop it is to either turn the knob on the boiler to 0 or very low, or turn the power off to the danfoss. (I assume the switch to the right of the danfoss is its power?). It's a fused connection unit.
Is it possible that the danfoss is still feeding the boiler with power even though the programme is set to off? Or more likely to be a boiler issue?
Leon
Leon
