We have a Glowworm boiler that's behaving a bit odd tonight.
We have underfloor heating downstairs and radiators upstairs (zone valves on each). It's always cycled and not behaved very well with the UFH - it'll surge up to 65deg then switch off and then wait until temp gets down to 40 and then go again. No idea why and nothing seems to make it better. Consequently the rooms take longer than they should to warm up.
However, tonight with both sets of heating on, it's heating to 65 and then dropping the burn rate to the lowest it can (one flame icon) and then sitting with the flow temp at 40deg (return is 32) for ages then firing up again to go to 65deg. This isn't heating the radiators properly, nor is it giving the UFH the required 55deg flow. Both pumps are working, system was checked over in late autumn due to the UFH silliness. Water is clean and so on.
Radiators have always seemed fine and not taking long to heat up.
Anything else to check, any ideas?
TIA
TIA
