glowworm boiler
20 Jan 2009
Cambridgeshire
Hi
I have just moved in to my new house. The boiler system had been drained down.
I refilled it, bleed all the rads it worked fine for 2 days.
Today the pressure had dropped below 1 bar it was filled to 2 bar when working. So I refilled it to 2 bar but the boiler did not fire up. The pressure in the boiler just started to drop again and now is below 1 bar again. I have checked for any leaking rads but can not see any.
Any Help would be great :lol:
Thanks Robert
one check if blow off pipe is leaking
and run tissue round all rad vales if little wet then leaking their
use two spanner`s one for nut one for the valve
you are not recharging the expansion vessel ya lemon
you are filling the ch system
have you looked at the FAQS?
will post a link in a minute :wink:
sir if you wish to insult a plastic southerner the title is confederate
View media item 17065
View media item 17660
to the OP a thousand apologies
if system pressure is rising to 3 bar recharge exp vessel
if system is 1.5 cold rising to about 2 thats perfectly ok, but if the PRV is leaking at 2 bar, its better off to replace
