Glowworm CI Timer
12 Feb 2006
Buckinghamshire
I have a Glowworm 24Ci which has been installed a little over 2 years. It has already had one integrated electro mechanical time replaced under warranty and now that one is running slow (losses about 1 hour in every 24). I have checked it for binding on the case and it just looks like the motor is running slow. Glowworm tells me the Part number for the timer is A20086 for a mechanical one and A20087 for an electronic one. Unfortunately I cannot find any info on the web regarding those numbers. It seems that suppliers use there own part numbers! I can however find several suppliers of both Mechanical and Electronic times for the current CXi Model.
So now to my questions.
1) In Your opinion Is the electronic timer better than the Electro Mechanical?
2) Does the CXi Models use the same timers?
3) If the answer to 2 is NO any Idea where I can get one from?
Thanks in advance for you help
Mark
Dont what the other lads think but i have no end of trouble with these timers
I just remove them now and install and external one on like the ACL 711
Thanks for the tip Corgiman but I was hoping for a simple replacement rather than a re-wiring job. I suspect an electonic one would be better than the electro-mechanical but I still need to know if the timers for the 24CXi are the same as those used on the 24Ci?
Mark
They are the same clocks. Electro mechanical one is easy to work but tend to have this problem of slowing down.
