Hi, this is bizzare. I rent a property which has a glowworm ultimate 50 ff boiler for central heating. Boiler has been fine for a year until December 09. Then Unit would not fire up - constant spark clicking. luckily, the boiler is covered by BG contract. They replaced the PCB and all ok. the problem has happened again and again a total of 4 ( YES, 4) times since December - each time BG replaces the PCB and the electrode and cable. Now the last time they replaced the board, they also replaced the gas valve because they said "something else must be causing these PCB's to go faulty". That was 7 days ago and guess what, the same fault has happened again. Now I know I will be calling BG in the morning , but just out of interest, has anyone else had this problem?? From what I have read on these forums there are a couple of possible causes but so that you know, aswell as the PCB and the gas valve, the pilot flame jet assembly, the ignition electrode and cable have all been replaced. Any ideas ??? Like I said I know this will get fixed again but it is becoming a nightmare wondering if the heating is going to be on in the morning or when I get home from work - the time between fixes is getting shorter and shorter...
Many thanks in advance, paul
