My property will be empty for several weeks this winter and I want to take precautions to prevent possible freezing water pipes.
I have an electric central heating system (so no heating pipes to worry about!) which I could leave running if necessary on a low setting in rooms containing water pipes but I would prefer to save energy and find an alternative method. Here are my questions:
1. Could I be sure of no problems with frozen/burst water if I just turn off the mains water at the main supply tap inside my house and 'drain' the sink/shower/bath taps and MAIN gas multipoint boiler (just a hot water boiler, not a combination) before I go away?
2. When I tried this draining operation earlier, turning main water supply tap off first then each domestic hot and cold water tap in turn, the only place I found any water to drain was from the multipoint boiler (a MAIN gas water boiler, not a combination boiler). As no water came out of normal taps, is draining in this way (once main supply is off) a waste of time?
3. If I should drain individual hot and cold water taps should I leave these taps (at sinks/shower/bath) OPEN when I go away, or should I CLOSE them (main supply tap off of course!) and what's the logic behind this decision?
Thanks for any advice you can give me.
Ray
Ray
