Hi.
Im hoping cause the boiler is fairly popular someone might recognise this issue.
Recently discovered the flow switch on our grant Vortex combi boiler was stuck on and therefore not allowing the central heating to run, it cuts off the central heating pump if hot water is needed.
Easy enough to remove the switch and I gave it a clean and a wiggle on/off to check it works. It does.
So I reinserted It, tightened it up and it worked fine for a while but last night it happened again - flow light staying on when no taps opened so heating not coming on. I removed it once more to check and I have noticed that just inside where the flow switch paddle sits there is quite a lot of scale, this could potentially be catchingthe paddle - can I tip a bit of descale in that part of the pipe and see if that helps?
Thanks in advance for advice.
