Gravity fed cold and high pressure hot - mixer tap?
15 Jul 2012
Hertfordshire
Hi
I am hoping to get a bathroom refitted and I have the cold gravity fed from a tank in the loft and the hot comes in via the combi boiler. I am not too worried about the bath because we can already fill that via a mixer tap but I am not sure that we will get good results on the sink with a mixer tap. It could be tricky especially for the kids to get the right temperatue water coming through the taps. Am I better off getting two taps - one hot and one cold? There don't seem to be so many of those sort of two hole sinks around I don't think.
Any advice would be appreciated
Thats only possible if the dynamic flow rate is adequate.
You can use a pressure reducing valve.
Some find the pressure equalising valves sometimes work but they are expensive.
Tony
Thanks for your responses though I think taking the tank out is a little drastic (and the extra tank has proven extremely useful in the past through several water cuts
In the end I went to the BathStore and they sold me a sink with two taps
Cheers
