It isn't "end of story", because valves enable the rad to be removed without draining the system.doitall said:...it shouldn't have any valves. end of story.
Softus said:It isn't "end of story", because valves enable the rad to be removed without draining the system.doitall said:...it shouldn't have any valves. end of story.
If the rad is inteded to be a permanent heat sink then both valves should be lockshields.
Quite so, but it should have valves, for the reason I've already given.doitall said:It is an extention of the primary circuit.
