Hi Guys,
After numerous years of thinking about putting in Radiators into my parents house I eventually got it completed.
The ehat source is off of a back boiler on a Stanley range. The hot water is by gravity. The pipe work is one inch from the back boiler to the copper cylinder. The copper cylinder sits in a hot press about six feed from the boiler and about 5 feet off of the ground.
The gravity hot water is functioning perfectly. buckets of hot water.
Is it possible to have convection heating upstairs? The reason I ask is that I thought we could and I don't. Basically I T'd off the hot water loop and put in a radiator loop. This run is about two feet higher than the heating loop and then runs horizontal for a metre. (this is where the heat stops) This I think is causing the issue but how could it? considering that all the pipe work for the upstairs radiators is horizontal. The radiator loops are 3/4" tapped off 1" gravity feed heating on the cylinder.
I have installed a Pump in the return loop for the downstairs radiators. Wired this up and turned it on and this circulated the hot water around to all the radiators upstairs and downstairs.
It will function with the pump but can I get it to function by convection?
Thanks for your help.
Aceman3
Aceman3
