Gravity Hot Water or Fully Pumped ?
29 May 2005
I have a Best 50 Boiler, a pump !, a mid position valve.
How do I tell if my hot water systemis fully pumped or gravity fed?
ta
nick
if you have a 3 way valve it will almost always be fully pumped, but if you really want to make sure then turn the water / ch on individuallyand make sure the stats are calling, if the pump starts for both then it is fully pumped.
presumably a room stat for example is calling if the temp is below the required setting and then is satisfied once the temp is reached ?
thanks
