Help, I have a problem getting gravity circulation going through an indirect cylinder. Rayburn LPG, pumped central heating with check valve on CH flow and pump on return, f&e feed taps into top of return at cylinder, expansion into top of flow at cylinder. Have tried to kettle system, back fill through drain-off and lots of other things. System is 20 years old, cylinder replaced 4 years ago with standard indirect model (not dedicated gravity coil) and has been working fine all that time. I'm getting heat to heat leak rad and all CH also heat at flow tapping on cylinder. Return remains at room temperature! Am tearing my hair out (whats left of it!!) Does anyone have any ideas? Thanks
