im in the middle of taking out my old gravity system and need some advice on converting the current pipe work at the hot water tank ?
I have taken out the loft tanks etc disconnected the hot water cylinder and cut and caped off the two pipes that go down to the old back boiler so what I have remaining to deal with is 3, 22mm pipes,
one came from the bottom of the old cylinder (I'm assuming this is the return ?)
One came up into the pump then a zone valve then to the top of the cylinder (flow ?)
The 3rd pipe came Up from the floor to the zone valve, I'm assuming this is the heating flow ?
My bathroom rad was hot when the hot water was on so I'm assuming this was connected to the boiler flow and return
So my question is should I connect the two "flow" pipes together then feed them back to my new combi ?
And the return to the one that came from the bottom of the tank?
I have been trying to find a diagram but nothing like the setup I have
What was also confusing me was that the little header tank in the loft was connected to what I'm assuming is the return (bottom of the tank) all the diagrams online are showing this connected to the flow (same run as the pump)
Your help/advice will be appreciated
