Green oak or soft wood posts for flat roof canopy (duplicates merged)
9 Mar 2021
For a 3.7mx4.7m
Flat roof with epdm
10 9x2 joists at 400 centres
Also 2 skylight panes of glass
Wall plate on house then 2 posts the other end sitting on piles and steel post bases
Do i go 8x8 green oak or 8x8 pressure treated softwood.
They wont be sitting on the ground and i will intend to male sure both have been treated with oil.
Soft wood posts are £65, each green oak posts are £150 each.
Just unsure what to go for, so advice please
For a 3.7mx4.7m
Flat roof with epdm
Wall plate on hous then 2 posts the other end sitting on piles and steel post bases
I’ve just bought 2 6x6 PAR oak posts for a lean-to porch, £120 each all in. Not cheap but looks miles better than a tanalised post imho. I might treat them with osmo UV oil too, to slow down the greying.
PS not sure oiling pressure treated will work.
Tbh im not bothered about the look as other timber putside i have has been stained to match window frames.
I think you can oil the pressure treated but you have to wai a bit to do it.
Its more based on will pressure treated softwood last, i cant ifind any information on this only for timber with ground contact
Green oak is very pretty. Pine is pine. Upto you. Mind you nothing pine lasts in the elements.. For example, the roman style oak washhouse in my parents garden is 150 years old and just gets prettier with age. Your call really.
I think it was more will it last another 50 60 years . Without meeding to replace as i dont want to buy the green oak if its just not needed
