Hi there,
I hope someone can help with our problem.
We recently moved into a new property, which is a smallish 3 bedroom house. We are renting.
The boiler installed in this house is a Greenstar Junior 24i.
We have noticed since we moved in here last month that the boiler is taking a long time to heat up the water when we turn on the tap. What typically happens is: I turn on the tap in the kitchen (the boiler is in the loft), and the water initially comes out cold, and 5 seconds or so afterwards it starts to get warm/hot, which continues for the next 10-15 seconds or so.. then the water gets freezing cold for the next 10-15 seconds or so, after which time, the water starts to become warm, and then within the next 20 or so seconds, the water is boiling hot, and it stays this way. It usually takes about a minute or longer to get boiling hot water.
Is this normal?
The same pattern occurs upstairs in the bathroom (which is nearest the loft), although it doesn't take quite as long as the kitchen to heat up the water. Usually by about a 45-50 seconds the water will be boiling hot.
If I try the bathroom tap shortly after I have used the kitchen tap for hot water, then the bathroom tap will heat up quickly. (I"m guessing this it because the boiler has just heated up the water because I used the kitchen tap?)
Anyone have any idea? we contacted out letting agency about this last week, but at this point I didn't realise just how long the kitchen was taking to get hot water, and thought there was just a bit of a delay in the bathroom, where I had to wait for the water to get hot. I was told this was normal with this type of boiler, and that the boiler has to get rid of it's water first, which is why the water comes out cold/warm for a while, and then heats the water up again from scratch. This sounds a bit far fetched to me.
We have a boiler guy coming over one day soon to try to resolve a different problem as well with our central heating.. there is no timer set on the boiler (as far as I'm aware, as the last engineer to visit the property advised that it was turned off), so the heating should all be controller by our thermostat on the wall.
For some reason, at certain times of the day, even if we put the thermostat on 32 degrees, the boiler doesn't turn the central heating on. We can hear the thermostat clicking to show that we are increasing the temperature etc. All throughout this time, the water is still being heated when we turn on the tap.
The boiler has a blue light on the front, and the ECO function is not turned on.
According to the manual for this boiler, it should be able to 'pre-heat' the water when the ECO light is not lit, so why is it taking sooo long to get hot water out of the taps?
thanks for your help,
andy
Is this normal?
andy
