Am hoping one of you experts (or DIY'ers!) can (please!) help with following: -
Installed Grohtherm Wireless pumped shower 18 months ago next to gravity fed HWS cylinder heated by off-peak immersion. All working fine until last week.
Returned from week away to find HWS immersion thermometer safety cut-out had tripped which meant that tank was now luke warm. Reset this (cause was wife hanging towels off HWS tank which covered the immersion
) and HWS reheated fine.
However, after HWS tank was back to normal temperature shower struggled to reach the standard 38C - I measured temp of water from HWS and it was 52C so ok and well within unit limits.
I than ran Inlet Valve cleaning procedure and after this the shower worked fine again - for 3 days. This morning had same problem - not reaching temperature.
If anyone has seen this before and knows of likely problem/fix that would be appreciated!
I haven't yet tried uncoupling the unit and cleaning inbound valves/filters (partly because there is no way of isolating inbound hot water as gate valve fitted to hot water feed is broken
) so I need to wait for weekend when I have some time. I did wonder if cartridge could be failing - but that wouldn't explain why it has worked for 3 days again?
Pressure/flow etc from shower is fine no obvious change from before.
I can get shower a bit warmer by increasing dial to say 42C but even when doing that the output water temperature is around 30C mark.
Thanks for your help.
