Ground supported floor advice - is screed layer necessary?
13 Feb 2009
Looking at the regs, there are several diagrams for solid ground supported floors, one of which illustrates ground supported floor construction being (in reverse order):
1. Compacted hardcore (max 600mm)
2. Sand blinding (min 50mm)
3. DPM
3. Rigid insulation (min ?)
4. Concrete (min 100mm)
...there is no mention of a screed layer to finish. Is the screed absolutely necessary? Or is it simply a leveling layer?
Also, what is the min thickness of rigid insulation under the floor?
Any advice much appreciated.
We always opt for a screeded floor when building extensions etc for two main reasons.
1. You can finish the concrete sub-floor within the realms of say 75mm lower than the existing without the need to be outrageously accurate. Then, once you do your knock-through you then remove the dividing masonry to below concrete level, fit some insulation and polythene and screed right up to existing, ensuring a seamless floor.
2. As well as achieving a seamless floor you can also achieve a decent finish without the worry of power-floating and bad weather, especially relevant in the Winter time. Concrete would take an age to firm up enough to power-float at this time of the year.
Many thanks for clarifying Noseall.
I've seen hardcore/concrete/insulation/sand&cement screed spec'd so many times now that I assumed the screed was part of the regs!
