I'm seriously fed up with this cistern (close coupled toilet from B&Q).
I've sorted one leak and now another. Where the flush valve goes through the bottom of the cistern it will not stop seeping, which results in the top of the pan filling up with water and the water seaps out between where the bottom of the cistern comes into contact with the top of the pan.
I've tightened the back nut as tight as I can. I'm now contemplating either using a ton of SLX leak sealer around the washer or simply taking the crappy thing back to B&Q. What should I do? I'm amazed they are are allowed to sell these things, especially in a DIY store. How is the average DIYer supposed to do anything other than follow the instructions?
Also, the large foam washer is now deformed because I've had to take it apart so many times.
