As far as I am aware neither of the two models of Grundfoss Home Booster have any fault display.
Can you not see a model number on the unit?
What are "Euro Pump" to do with it? What do you call a "massive cost" for a service? Dont you think that servicing might help to prevent breakdowns?
The home booster is very similar to our pump sets, and the fault you describe usually refers to the fact that the onboard tranquiliser vessel is not pressurised. It needs to be pumped up to 90% of the cut in setpoint - so if the cut in is 2.5 bar, you will need to to pump it to 2.25bar
