Hi, I'm installing a new Grundfos MQ 3-45 water pressure booster pump and have got fittings to take the 15mm supply on to the 1" inlet port (and the other way round for the output). I need to fit the non-return valve (supplied) into the inlet port but the 1" female end of the fitting does not seem big enough to incorporate the valve. I not confident enough to try forcing it.
Any suggestions please? I got the fittings from a plumbers merchant but they just seem to my amateur eye to be standard plumbing fittings and maybe not necessarily ideal for connecting a pump like this. Are there specific fittings available?
I've tried emailing the pump suppliers but they were less than helpful now they've got my cash.
Cheers,
Brian
Cheers,
Brian
