Hi all,
I seem to have a problem with this pump. I installed the pump and whole bathroom about a month ago and everything has been fine till tonight.....the bath was running (also powered by the pump) and then suddenly it stopped.
THe pump is located next to my CH cylinder, fed from a warix flange for the hot and has a dedicated cold water feed from the tank in the attic. The output of the pump goes back up via the attic and then down a wall cavity to a thermostatic valve that feeds either the shower or the bath.
Basically, the bath was running fine and then the pump stopped. WHen i went in the airing cupboard, you could smell the resin from the windings - like you get with a new pump. I assumed that it has overheated and stopped itself.....dont know why as it was only running for a few minutes. However, when i waited 1/2 hour and then tried it again....it does not start!
I checked the fuses - fine.
Any ideas?
Matt
Any ideas?
Matt
