Grundfos pump getting air in
10 Feb 2007
Leicestershire
Hi i have a grundfos 15/60 about 6yr's old, recently i have had to undo the bleed screw every morning to get hot water running through the pipes. It takes about 30 sec for the water to start dripping out and the pump then becomes noisy but the rads heat up. i have checked all the joints around the pump and valves with a w/up soloution and there does not apper to be any leaks. This only seems to happen when the heating has been off e.g. on timer or i have tried leaving thermostat on low over night but they are still cold in the morning and i have to vent the pump again. Any ideas?
___________________________
lynda, moderator
your title has been edited, see forum rule 5
WHat I mean is, is it in a section of pipe which could collect air from the pipework when the pump is off? Like an inverted U.
