Gurgling
28 Oct 2007
Buckinghamshire
i have a saniflo macerator, when the toilet is flushed iget gurgaling from the pipes.
Ihave measured the run its 10 meters long ,and falls 250mm.the pipe work is 32mm. Can any one help.
I don't know about gurglaing or gurgaling.
I thought they all went
Awwaaaaa-nya-nya-nya-nya-dshjuuuuuuu-neeeeee-shooooooo-ah
What sounds wrong about your gurgling?
Are you sure you spelt that correctly ??
Is there not a Shiiiiiiiiiiiiiiiite in there somewhere ??
perhaps is some stuff running back down the pipe? open it and have a look :lol:
You mean the dugga-dugga-duga-duga-dug-dug-g-t-t-t-prroooeep ?
how long does it go on for?
It goes on until it hits the stack.You can hear it as it goes down the run.The pipe run has 4 92.5 bends in it could this be the problem
Having looked at the pipe run, i canot see a way to open it except where the pipe enters the macerator.The only other way would be to cut the pipe NOT a pleasent thought at lunch time.
