Hi Guys,
Looking for some advice on an issue that's driving me mad.
This applies to one floor only, the other 3 floors blow them on a normal basis (one a month at worst)
The Kichen and utility floor (basment) has it's own CU there are 15 halogen downlights, on a 3 gang dimmer, rated at 400w per gang.
6 lamps on first gang, 5 on second gang and 4 on third.
I had issues with the electricians who rewired the place and had to have them back quite a few times before the trip would stop blowing down there also in a week the lighting destroyed 3 dimmer switches.
Anyhow to my issue, a lamp will last a maximum of 40 hours before it blows, sometimes they will blow within a few minutes.
It's got to the point that I only have 2 bulbs in each section as the cost of changing the whole set is crazy.
I have used Cheap and nasty, I have also used Expensive and have even tried some that have 10,000 hours on the side of the box. Makes no differance which ones I use, they still go POP !!!!!
Should I upset my electricians again and get them to check the wiring is OK or is it a Dimmer/Halogen known problem???
Many Thanks
Many Thanks
