Halstead Ace High Burner probs
20 Feb 2007
Manchester
Hi, Any one out there tell me why when the hot water or heating is turned on the Burner fails to ignite occasionally , i get the green water light on then usually the green burner light turns green when the burner kicks in, but now and again nothing ! it usually has to be turned off for between 10 and 30 mins before it starts to work again.
dont know if this will help but ive noticed the burner light to be a little dimmer than usual.
Thx
Probably the gas valve/PCB setup but thats a CORGi job so I cannot give you detailed instructions.
Tony
