Halstead Ace High CH min flow rate
6 Nov 2020
Hi, I have a Halstead Ace High boiler in a system that has an automatic bypass valve in the central heating circuit.
I cannot find any info on the minimum flow rate for the heating circuit to deduce the setting of the valve.
Anyone know this or can point me in the right direction?
Many thanjs
Thanks for the link but it is the boiler's minimum flow rate for central heating that I need.
Without this, I cannot read off the valve's graph.
Note: The boiler incorporates an automatic bypass, hence no other
system bypass is necessary. However, it is recommended to fit TRV’s on
all radiators except in rooms with a room thermostat.
If no room thermostat is fitted, at least one radiator (preferable in the
bathroom) must be permanently open, i.e. fitted with two lockshield
