    Dismiss Notice
Halstead Ace High Diaphragm
Discussion in 'Plumbing and Central Heating' started by jaguar49, 13 Jun 2017.
  1. jaguar49
    jaguar49
    16 Jan 2005
    30
    Thanks Received:
    Country:
    Is their a guide to replace the diaphragm on the above boiler as the pin isn't quite reaching the micro switch for domestic hot water one of the silver slotted screws at the back seems impossible to get a screwdriver on it, or do you undo the 2 brass slotted screws to the left of the diaphragm housing.
    I have read other people saying its only a 20 minute job !
    Would appreciate a guide or info how to do this job.
  2. Sponsored Links
  3. PullerGas
    PullerGas
    11 Jul 2015
    6,065
    Thanks Received:
    1,205
    Glasgow
    Country:
    Simple guide; get a Gas Safe RGI in!!
    • Like Like x 2
  4. bazdaman
    bazdaman
    2 Feb 2010
    1,380
    Thanks Received:
    316
    Lancashire
    Country:
    Take the housing out
  5. ianmcd
    ianmcd
    15 Aug 2010
    20,506
    Thanks Received:
    7,979
    Lanarkshire
    Country:
    a very easy job , as advised just remove the diaphragm housing
  6. jaguar49
    jaguar49
    16 Jan 2005
    30
    Thanks Received:
    Country:
    Hello is the diaphragm housing secured by two brass screws ? Do I turn off the water in the street and then open the drain valve to drain the boiler or can I get away without draining the boiler ? Thanks
  7. ianmcd
    ianmcd
    15 Aug 2010
    20,506
    Thanks Received:
    7,979
    Lanarkshire
    Country:
    you dont need to drain the boiler , turn the water off at the cold water inlet valve below the boiler open a hot tap till the water stops running and take the housing out, yes held by two screws
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
