Hi Guys
My boiler has developed a fault which is puzzling me.
As from yesterday the boiler will ignite normally and run for 3 to 4 minutes and then close down. I can hear the pump still running and the HW thermostat is demanding 'heat'. All the radiators remain cold, the Thermostat is still demanding 'heat'.
The problem occurs both for HW/CH or just HW.
I might of suspected a problem with the 3 port valve, but the problem still exists if I manually open the valve using the small 'lever' on the valve head.
Any ideas would be appreciated.
Thanks for taking time to read about this problem.
Mahadev
Mahadev
