Halstead Platinum, DHW ok, No CH
22 Jan 2007
My boiler is 1 year old and tripped out with excessive heat as the fault cold.
I ran it in DHW mode for12 hours with no problems. I am now trying to get the CH working and now it doesn't trip but does not respond to CH demand.
Room stat is max and timer is on.
Does it do anything - click, whirr..? Worth checking external controls if not.
Hi Chris
The boiler did nothing, I checked externals and found a faulty room stat, I relaced this with a shorting link and the boiler now does it's start up checks but still no CH.
Halstead suggested I turn the control to the spanner setting, this should fire the boiler up in low heat/service mode, this had no effect.
The knob was found to have a broken spindle and the ch now works.
