Apologies for the simple question! But with hammer fixings which bit do you hammer? I'm assuming the plug into the wall but I thought it's better to have it push tight so you don't quash the plug in the hole.
The plug goes through the item being fixed and the screw is hammered in. A lot of people make the mistake of putting the plug into the wall and only the screw through the fixture. As DAZB says, a half turn at the end ensures a good tight fixing.
