    Dismiss Notice
Hang on the wall gas fire - pre-cast flue
Discussion in 'Plumbing and Central Heating' started by Witty01, 22 May 2016.
  1. Witty01
    Witty01
    22 May 2016
    2
    Thanks Received:
    Country:
    Hi, I'd really appreciate some advice on the suitability of a gas fire we're looking at.
    We have a pre-cast flue, with a conventional looking mains gas fire. currently inset. This limits our choices due to the depth and means modern looking hole in the wall fires are not suitable.
    We looked at flueless fires but put off by safety concerns. Then found the flavel curve http://www.flavelfires.co.uk/products/flavel-curve-gas-fire which seems to meet our needs.
    Unfortunately one supplier has told us that the fire wouldn't fit as it would mean disrupting the starter bricks, potentially causing flue collapse. Before we dismiss the flavel curve i'd appreciate others opinions on this matter.
    Any advice would be gratefully received!
  2. lightning
    lightning
    14 Jul 2007
    1,937
    Thanks Received:
    411
    Cambridgeshire
    Country:
    Can u fit a balance flue model
  3. Witty01
    Witty01
    22 May 2016
    2
    Thanks Received:
    Country:
    Yes, but it would be significantly more expensive.
  4. DP
    DP
    10 Dec 2003
    12,601
    Thanks Received:
    2,549
    Glasgow
    Country:
    Replace with an outset fire. Much better heat output.
  5. DIYnot Local
    3 Sep 2019
    Country:
  6. Sponsored Links
Loading...
Share This Page
