Hello everyone.
Bit (quite a bit) worried that something bad is going to go wrong with my boiler.
I've finally moved home to a house with a Baxi Inset 50/4 Bermuda back boiler and found that the timer on the controls wasn't working. I called out a local plumber and got a new digital programmer which is great as the old one only had two on times where as the new one has three. I can't honestly say that this fault has been here all along as I was only in the house a few days when I got the new timer installed but what I've noticed happens is when the thermostat in the hall clicks off, I can hear the pump shut off however the boiler still stays lit, starts to bang like hell then shuts off followed with louder banging then eventually settles down.
To replicate the fault and with a cold system I set the hall 'stat to 10 deg (ie clicked off) and turned the boilers own 'stat to 0 and switched the programmer on to call for heat.
Now I'm no expert but I would expect nothing to happen when I slowly turn up the boiler stat as the hall one is still thinking it's hot enough and not clicking on. What happens is the pump does nothing yet as soon as I turn up the boiler one the thing fires up then after a short while bangs then cuts off. (guessing perhaps over heat protection?). I thought if anything the boiler would switch off first then the pump a few seconds later to remove heat from boiler and not other way around?
To satisfy my worries a bit and to keep using the system till I figure out what to do I've set the hall stat to 30 deg so basically the whole time the heating is on the pump will be on continuously. The water gets up to temp, the boiler shuts off and the pump keeps pumping then when the timer turns off so does everything else and no loud banging.
So, good people of DIYnot... what do you recon? Is this normal or should I get someone out to check things out?
Many thanks for reading
PS..
Old timer is a Horstmann 425 I think (looks the same)
New one looks like a drayton LP522 (again, looks the same)
Steve
PS..
Steve
