Hi - new guy here and need a bit of advice.
Just had a new condensed boiler fitted for traditional central heating/hot water system and I think the installer screwed up.
He wanted to change the feed from the expansion tank to a different pipe. Don't know why and I've changed it back now. To do this, he closed the valve on the return feed from the immersion heater. However, he did not open it again when he started up the system.
Now, the rads will only heat up when I have the hot water switched on - when it is CH only, just one radiator will come on.
Question is, did the pressure from the closed vale feed back through the 3-way valve and either jam it or break/bend whatever is internal?
