D
Deleted member 221031
Right wingers are hardly likely to be “pro trans” are they ? The opposite in fact.Thanks to right wingers.
It's really quite obvious. If transwomen are allowed to use women's toilets, but they don't have a GRC, they may still have the label of Male on their birth certificate. But because they are transwomen and they choose to use the women's toilets, then it stands to reason that those toilets are single gender spaces.Considered by you.
That makes no sense. Your ramblings are now embarrassing. What are you even trying to say ?It's really quite obvious. If transwomen are allowed to use women's toilets, but they don't have a GRC, they may still have the label of Male on their birth certificate. But because they are transwomen and they choose to use the women's toilets, then it stands to reason that those toilets are single gender spaces.
Don't be silly. I posted the 4th paragraph in totality.You chose to hide the vital point, in order to place your own emphasis, and your own interpretation of what you would have liked it to say (but doesn't)
As I said, occasionally a space can be defined so that it over-rides the Equlaities Act.Very helpfully, Roy's article goes on to say:
"If a trans woman who doesn’t have a GRC wants to access a female-only space, and is refused access, that’s not discrimination on grounds of gender reassignment, but discrimination on grounds of sex. She’s refused access not because she’s trans, but because she’s both legally and biologically male. That means she can lawfully be refused access any time it’s lawful at all to have a female-only space"
As society accepts that the role defined at birth, by the sex label allocated, does not always mean that the person will be content to be defined by that role, there may well be a rise in people undergoing the trans gender process.If Transtype behavior becomes accepted, the numbers could rise exponentially as all types of perverts could jump on the bandwagon.
www.diynot.com
Persistently posting pointless slogans is abuse as well.It is a term of abuse used by transactivists in an attempt to diminish women who do not agree that a man is a woman.
There are exceptions for the equalities act.This is correct and the reverse could be unlawful
Don't be silly. If I argue that everyone is Asian, it wouldn't be discrimination against Asian people.Not true. To argue that they are women is to discriminate against women.
Please do, then I won't have to deal with your comments aimed at me.I think Roy needs to go on ignore. He's a serial fruit loop.
Think of it as a continuum line, with Male at one end, and Female at the other.There are how many biological sexes - male, female, intersex - that's it all this gender nonsense is confusing and not helpful.
