Help! I have removed one rad downstairs and connected the pipes in a U bend, thinking the flow would just continue on with no rad there.
Obviously there are no valves now so some of the system was drained down. Now i have no heat. The pump works as does the boiler, and i have hot water.
There is loud banging when i turn the heating on so i also tried bleeding other rads. Nothing much coming out there so i'm wondering if there's either a huge air block somewhere or no water in the system at all.
I checked a valve coming off the heating reservoir in the loft which seems to supply the pump and the boiler, it just spins, doesn't seem to open or close!
Is there a way of draining down completely and filling up from scratch?
Many thanks for any replies.
