Hawk FER Combi boiler wont fire up for the heating
30 Dec 2005
Hello im new to the site which ive been looking around today looks good guys
well here is my problem
1) Boiler make / model -- FER Hawk Combi Type C1 GAS
2) What is / is not happening -- Ive got hot water and the boiler fires up well. But when i want the heating to come on it trys to fire but dies and a little red light come up on the board some times it will fire and run for a few mins then die again the rads luke warm but nowhere near hot.
things ive checked
pressure is at 1.5 bar
pressure swicth is working
pump is spining
fan is working
and everything works when i want hot water just not the heating
3) Has ANYTHING else been done / changed recently not that i know of
4) When did it (problem) start -- a few weeks ago
5) When does it happen? -- heating coming on
Try measuring the resistance of the temperature sensors ( if you can ) ideally with everything cold.
Tony
Hiya thanks for the reply
im not getting anything from the heating sensor but im getting 9.11 on the hot water sensor
Try swapping them over ( after draining ) and see if the fault swaps over!
Tony
thanks mate will try it tomorrow will let you know how it goes
also have you ever heard of my boiler
I would not risk replying if I had never heard of it!
It would be the legless leading the blind!
There is only one boiler that I have not heard of yet!
Tony
lol thanks its just everyone ive rang said they dont know it and ive been looking all over the net for the makers without any luck but i will try what you say and will let you know how it goes :)
Its a ferroli in drag.
I'm not familiar per se but you will probably find it's the CH thermistor. Rather than swap the sensors over you can often swap the leads over BUT ONLY FOR TESTING PURPOSES
i did what you said and YEs the boiler fired up and ran untill i turned it off
so i guess its down to that sensor
is there a proper name or part code for it and where could i pick one up
and last of all thank so much for helping me out
cheers guys
craig
Ferroli have a very good website where you can download service manuals. www.ferroli.co.uk I have a Ferroli Modena102 about 6 Years old the thermistors are the same for CH & DHW it is policy to change both. I found mine on the net at BES in Birmingham, You might find locally if youre lucky, cost about £4 each.
Hope this helps.
JonB
thanks thanks thanks you guys are so helpful ive just downloaded the book for the boiler which will be a big help
