Over last few years, I've had various work done to flush CH system / unblock pipes and it's been working fine for over a year now.
The other day, I had reason to check the header tank and was surprised to see not just murkier water than I'd seen in the past, but also a kind of rust coloured 'skin' all round the inside of the tank at water level or just under, probably protruding about 2" into tank. In some areas it seemed quite thick.
Just unsure if I should be concerned and / or whether any action is needed given, as mentioned above, that everything seems to be working fine?
Cheers,
Mike.
Cheers,
Mike.
