Heating and hot water not working. Potterton Suprima 40l
28 Feb 2007
Can anyone help me with Potterton Suprima 40L?
I came home today to find the heating and hot water is not working? The timer is set as normal and lights on. The boiler had orange and green flashing light. I tried reset but no joy. I have switched the boiler off at the electric point for 20 mins, turned back on, but it is still not working. Light was flashing orange and green as if it was trying to start, then just flashed red. Any ideas on what to do next before I call somebody out? The boiler is only 2 yeras old.
Luke
unfortunately could be several things to check but as its a suprima then chances are it's the pcb. call someone, out not much user can check if all controls are calling for heat.
Baxpoti may have some other suggestions if he reads this post
Thaks for quick response.
Any recommendations of anyone to call out, based in South East London
Luke
No one specific but a local installer , corgi reg is a must. If pcb expect around £300 for repair :cry:
Lukechap said:
just flashed red
How frequent is the flashing? once a second, three times a second or faster?
Is it flashing 'red/off' or 'red/orange'?
I pressed and held reset for 20 secs. Light then just went red, it is on all the time. I switched whole lot off for 90 mins then back on, it is still just a red light now, not flashing. but not as bright as it was.
Luke
I have noticed the electric has been off today, could this have caused a problem
Press and hold reset for 10 seconds/until it blips orange
Switched power back on. Red light just remains. Pressed reset for 10 secs - no change
Luke
I have a 2 year old suprima 50L with almost exactly the same problem you describe - have done some reading around and problem appears most likely to be the PCB - this boiler appears to be infamous for having bad PCBs. It seems generally to have more than its fair share of faults and reliability issues too.
Thanks for letting me know. At least it reassures me to get someone out to have a look and not just someting simple I have turned off by accident.
Cheers
