HI folks, here's the scenario:
3 Bed bungalow with converted upstairs containing bedroom/ensuite and office. Rear extension kitchen/living space open plan. Built 2009/2010 and well insulated.
Currently heating has two zones, downstairs and upstairs, with a basic Horsmann timeclock (2 Zones + HW) and TRVs. There is a room stat in the upstairs hall which doesnt seem to do a lot ie I'm not convinced it actually kills the boiler, and in any event someone has parked it directly above a radiator!
Total 14 Rads across what I'd like to become 9 'zones' as the current zoning doesnt do much for us.
Temperature control within the zones is quite important as we have a couple of log burners in different rooms downstairs and we want to make the most of those.
So whats the options?
Cobble together some sort of system from the Conrad Thermostat/Valve actuators and boiler interlock? If thats the way to go, should I keep the time clock on the boiler and install two boiler controllers in series with the output of the current two zones so I can override it to OFF at any time and still keep the DHW timer independant of all this to back up the solar water heating in the summer?
Honeywell Evohome stuff any good? is this a DIY install and do I lose my two zones? I work from home a lot so heating just the upstairs for the office is handy, and with programmable TRVs in the bedroom it shouldnt be getting heat during the day etc.
Pegler i30 valves and the PC control suite/USB stick - does the PC programming simplify setup, and more importantly can it easily reprogramme all valves if i did a mass battery change in the autumn for example? Any options for boiler interlock?
Danfoss Z Wave stuff - looks crazy money and probably too clever for what I want?
Any other suggestions?
One other thing, although I have a zone for DHW, the tank gets heated when any of the boiler zones are being run. Having the solar panel for DHW I'm not sure that is the most efficient - should I be avoiding applying any boiler heat to the tank in the morning to make the most of any sun during the day and leave any water topping up to be done during the boiler's evening heating cycle?
