Hello, I am working in a flat with communal heating from a large boiler which does the whole block. I currently have 22mm flow and returns in the flat I'm in with isolators so I can work off of them.
The customers wants a programmable room stat to set on/off times and obviously gauge the temperature.
I have asked the electricians on site, if I cut in a Honeywell zone valve on the flow will they fit a prog room stat to open and close it accordingly. They have said this is no problem if I can provide them with a wiring diagram.
Does anyone know, firstly, if what I have suggested is possible and if so, where might I find a wiring diagram for such a set up.
Forgot to mention, the boiler will be on constant so I will only need the stat to open and close the zone valve, not fire boiler, run pump etc.
