Heating / hot water / underfloor heating issue
10 Nov 2013
West Midlands
Hi all
Moved into a 4 bed property where we have a 35kw system boiler that has a hot water tank which is controlled by a hive controller.
Also have a manifold which serves 2 zones one for kitchen and one for utility.
The schedules are all separate , no overlaps.
Thing is when we use the heating along side the hot water schedule, the radiators don’t warm up as much as they would when they running by themselves.
Same with underfloor heating.
Is this the case with all systems like this? Or is something not quite right?
Thanks in advance.
35Kw seems massively oversized! Wonder if it’s been range rated? What motorised valves are in play?
Is 3 motorised valves ok? When the hot water comes on or heating I can hear the valve whirring. There are some visible levers on each that I haven’t seen move
thanks, is there something I need to check/change to make the underfloor heating more warmer when thr radiator heating is on?
Not really. It probably needs to be checked if it's been setup properly. Make sure there's adequate flow through the motorised valve, see if the boiler has been range rated, that sort of thing.
