- Joined
- 22 Dec 2007
- Messages
- 1
- Reaction score
- 0
- Country
hi folks,
am trying to fix "pitching" in my system
The oil fired part of the house is perfect, and an open system.
I also have a back boiler behind an open fire, but when this is lit, the system pitches, ie hot black water comes out of the expansion pipe.
I have checked the pump, that it is running, when the thermostat tells it to. Two questions in relation to the back boiler.
What temp should I have this at --70 deg ???
What setting should I have the pump at - 1,2 or 3 ?
The exp pipe is higher than the header tank, but could the water level in this header tank cause this pitching, ie too much water in the whole system ?
anything else to check,
thx
K
thx
K
