Following this on another thread. I can't get a plumber in today [sat ] so seeing if there is a simple fix. No stand by light on [ main power fuse Ok ], so I'm thinking fuses on the board. When I looked there was water coming from behind the 3 way valve. I'm an auto engineer - and I'm guessing water + electrics not good. I'm also assuming there must be a rubber seal that normally isolates the water from the valve.
If I'm correct so far, then my instincts are to remove the 3 way valve [ simple electric connector and clip ] and check condition of motor and see about ordering a seal repair kit.
Two very stupid questions from an auto engineer -
if I take the 3 way valve off to check - am I going to get a flood? Main water supply turned off.
Just where ARE the 2 fuses "on the PCB" ???
With a Wife and 3 daughters in the household you can see the stresss I'm under !!!!!!!!!! Help.............................
Read more: http://www.diynot.com/forums/viewtopic.php?t=218883#ixzz1dUeHyCRh
