My boiler fires up for 10 mins then goes off, tried on water and central heating and same happens. Oil in tank. What could be wrong and is there anything I can do?
Sounds like a problem with PCB if it is the same on both heating and hot water. It needs to be circuit tested after cutting out and before turning off power. If this is beyond your capability then call a professional.
