Heavy duty fixing for attaching climbers hangboard to brick
22 Mar 2006
Essex
Hi everyone.
I'm going to attach a climbers hangboard to an internal brick wall at home, it's a load bearing wall, and the hangboard will be above a doorway. The house is over 120 years old, I'm not sure what's behind the plaster, but assuming it's not timber. The board needs to take at least 90kg of weight
I was thinking that I should use a fisher bolt/sleeve anchor type thing (can you tell this isn't my specialist topic?) I'm thinking that I'll over-engineer the number of bolts (the board is to be screwed to 18mm ply, the ply is bolted to the wall). More bolts = less load per bolt. At the moment I'm looking at a 10mm diameter bolt/sleeve, going in around 8-12 cm. I'll also go quite wide with the ply to spread the load as well.
any opinions on this, or more important, experience of installing a hangboard?
thanks all!
8 Jan 2013
Surrey
Ok so for those of us not part of the climbing fraternity, what is a hangboard?
As to hanging off of the part of a wall above a doorway, I would not be overly confident in its ability to take the weight. The Victorians were not always that fussy about build quality and it might not be that secure.
M
munchingB
" The dirty 45 degree slopers and monos which are apparent on the Beastmaker 2000 have been removed to make way for some jugs...."
mate-are you sure thats for strengthening your hands?
why did they employ someone from razzle to write up the item description?
22 Mar 2006
Essex
An update for anyone in thinking of adding a hangboard;
I've used 12mm anchor bolts (100mm length). They go through 2 x 18mm ply, 6 bolts in total. The hangboard is screwed into the ply.
So far it's taken my weight, should I cause the wall to collapse, I'll let you know!
