    Dismiss Notice
Help - advice on Mold on Plywood
Discussion in 'Wood / Woodwork / Carpentry' started by MeoMeo, 3 Jul 2019.
  1. MeoMeo
    MeoMeo
    16 Dec 2018
    15
    Thanks Received:
    Country:
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    60,512
    Thanks Received:
    3,171
    Dunfermline
    Country:
    Cook Islands
    if it has been wet through the winter, there is a considerable chance of delamination. Even nominally WBP grade will do this in a week or two. post some pics, especially of the edges.
  4. MeoMeo
    MeoMeo
    16 Dec 2018
    15
    Thanks Received:
    Country:
  5. MeoMeo
    MeoMeo
    16 Dec 2018
    15
    Thanks Received:
    Country:
    @JohnD Noticed this evening the top layer of a few boards are 'flaking off'. I'm fearing this delamination you mentioned has happened :(:(:cry:
  6. Gerrydelasel
    Gerrydelasel
    5 Jan 2016
    2,217
    Thanks Received:
    186
    Lancashire
    Country:
    Plywood cannot be left outdoors in the UK Climate. I'm amazed that people think it can. Just look around you at anything made from plywood; billboards, hoarding, blocked-up windows... if it's been there for more than a few weeks you'll see it's always rotting and delaminating. Use plywood for temporary outdoor structures only.
  7. Sponsored Links
  8. cwhaley
    cwhaley
    10 Jan 2017
    782
    Thanks Received:
    62
    Erewash, Derbys.
    Country:
    That's not true. I was given a large shed for free but it needed a new roof. I laid 3 x 18mm plywood sheets on the roof and covered with thick roofing felt. That was nearly 3 years ago and the ply is bone dry and solid. My dad also used the same spec ply on a roof for a gazebo and that was nearly 10 years ago and still absolutely fine.
    As long as it's protected from the rain it'll be fine.
  9. Gerrydelasel
    Gerrydelasel
    5 Jan 2016
    2,217
    Thanks Received:
    186
    Lancashire
    Country:
    That was exactly my point. If it's protected from rain on one side and sitting above dry air on the other, then it's not outdoors, it's part of an indoor structure.
  10. cwhaley
    cwhaley
    10 Jan 2017
    782
    Thanks Received:
    62
    Erewash, Derbys.
    Country:
    No worries. I was just clearing up the fact that ply can be used indoors and outdoors if protected. Your comment reads as if you're telling people not to use it other than for temporary use. The underside of the roof overhang on my shed is exposed 24/7 but the roofing felt above it keeps rain off the top -- it is outside but protected.
  11. opps
    opps
    16 Jun 2006
    3,829
    Thanks Received:
    551
    London
    Country:
    My "temporary" backgate is now 18 years old. It is a sheet of 18mm WBP plywood. It did get a coat of waterbased fence paint (one side only) but, well that was 18 years ago.
    TBH I only expected it to last a couple of years but there is no delamination, so I have no plans to replace it.
    Given that the wind tends to come in from the west, it is slightly protected by the garage that it butts up to but under normal circumstances (ie) rain that isn't driven by the wind, the gate gets wet.
Loading...
Share This Page
