Help! Baxi 80 eco
18 Jul 2009
Cleveland
Been having problems with the hot water pressure on my boiler.
The problem is that bad, it takes a good 35 mins to fill the bath up.
To get a half decent temp i have to have the tap running a trickle, i'm also unable to use the mixer shower because of this.
I have noticed when i ask the boiler for hot water the boiler fires up with the flames on full but after about 5 seconds the flames drop to a much smaller flame. This happens when i ask for either heating or hot water.
I'm Thinking changing the temperature sensor.
But would require some advice first
Thanks Marty
Easy to do as its a dry pocket, make sure there's plenty of heat sink compound on the new one.
The problem could be a blocked plate heat exchanger, you would need to do some temp measurements on the flow & returns and hot & cold to know
more.
Will try and get the temperatures from the flow and return and the hot (why the cold ?).
What temps would i expect to get if the boiler was running good.
Where is the heat plate exchange and Whats involved in cleaning it.
Many thanks
Marty
82°C, 71°C, 50°C and 15°C
Plate heat is at the back, bottom, middle of boiler
Search forum for advise on cleaning.
