so if you suspected that it was the pump and it turned out to be the pump , what would circulate the water around the system , that would give them CH and HW while you had it was on test ??? your oscilloscope maybe ?? another post to be deletedIf I suspected it was the pump then I would have powered it from a fly lead and a 13 A socket!
Then the OP could have the full CH and HW system while it is on test.
Tony
If the circulator was fooked then what would be the point of a fly lead???If I suspected it was the pump then I would have powered it from a fly lead and a 13 A socket!
Tony
so do you expect the engineer to charge just for 10 mins then ????(Didn't call out same plumber as he said it would be £100 for the EP plus a further hour to fit!) Fitted it today in 10 mins
It is not a good idea to fault find by trial and error, each time a fuse 'pops' it means a high current has being drawn through the programmer / thermostat etc,
Have you read the whole thread dp ?
