Help installing Drayton Digistat +3rf to LP241/lwc1
29 Mar 2010
Clwyd
Hi there, can anyone advise me on how to add the digistat +3rf to my existing controller, an LP241 with LWC1 wiring centre. There is no room stat connected at all at present.
many thanks in advance
Do you have a Y plan (1 motorised valve on a tee) or a S plan (2 straight motorised valves) :?:
presumably a y plan, there is the lwc1 with wires to a pump and also to a valve (mid position actuator), the boiler is a backboiler behind our gas fire.
the pump, valve and lp241 control and lwc1 wiring centre all in the airing cupboard but i need to be able to better control the system from the lounge
just to clarify, on the digistat the terminals are N, L, 1 (common), 2 (heating satisfied or call for cooling) and 3 (call for heat)
which ones should i use?
